{"product_id":"cabasse-the-pearl-myuki-active-speaker","title":"Cabasse The Pearl Myuki Active Speaker","description":"\u003cp\u003eCabasse THE PEARL MYUKI is an ultra-compact, high-resolution connected active speaker designed to deliver a balanced, powerful sound from a minimal enclosure volume. Despite its small footprint, it is capable of up to 99 dB RMS output in mono, and up to 109 dB peak in stereo when paired with a second speaker. A DOM 45 midrange-tweeter and dual 12 cm bass drivers in a Push Push layout are engineered for firm, tight bass with impactful presence.\u003c\/p\u003e\n\u003cp\u003eDesigned for both home and travel, THE PEARL MYUKI supports a wide range of sources including TV, turntables, CD players, and network storage, and it can integrate into a whole-home Cabasse ecosystem using the StreamCONTROL app and AirPlay 2.\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eCompact high-resolution connected active speaker with powerful output for its size\u003c\/li\u003e\n\u003cli\u003eMono playback up to 99 dB RMS, stereo pairing up to 109 dB peak stereo with a second speaker\u003c\/li\u003e\n\u003cli\u003eDOM 45 midrange-tweeter with dual 12 cm woofers in a honeycomb Push Push configuration\u003c\/li\u003e\n\u003cli\u003eHigh-performance battery for up to 12 hours of playback\u003c\/li\u003e\n\u003cli\u003eSmart Wi-Fi network optimization for uninterrupted listening\u003c\/li\u003e\n\u003cli\u003eAutomatic room calibration with integrated microphone (CRCS)\u003c\/li\u003e\n\u003cli\u003eDFE mode for real-time power optimization based on volume, spectral content, and dynamics\u003c\/li\u003e\n\u003cli\u003eStreamCONTROL app support for streaming services, setup, and multiroom zone management\u003c\/li\u003e\n\u003cli\u003eCompatible with Cabasse connected systems, including THE PEARL COLLECTION and CLASSIC CONNECTED, with AirPlay 2 support\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eSound and Use Case\u003c\/h3\u003e\n\u003cp\u003eTHE PEARL MYUKI is built to sound full and controlled even at lower listening levels. The dual woofer Push Push architecture is designed to deliver precise, tight bass with deep resonance while operating within a very small enclosure volume. For larger rooms or more expansive listening, pairing two speakers for stereo increases scale and impact while preserving clarity and balance.\u003c\/p\u003e\n\u003cp\u003eWith multi-source support and automatic room calibration, THE PEARL MYUKI is well suited for living rooms, offices, bedrooms, and portable setups where you want high-resolution playback without a complex system. It can also be grouped with other compatible Cabasse connected speakers for multiroom listening.\u003c\/p\u003e\n\u003ch3\u003eDesign and Controls\u003c\/h3\u003e\n\u003cp\u003eTHE PEARL MYUKI features a lifestyle-focused design with rounded shapes and premium finishes in matte black or matte white with chrome accents. The woofers feature an embossed Lissajous pattern, and an integrated rear handle makes it easy to move from place to place. Control is handled via six illuminated tactile keys on the top of the speaker with subtle haptic vibration for clear feedback.\u003c\/p\u003e\n\u003ch3\u003eTechnical Specifications\u003c\/h3\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eSpeaker Type\u003c\/td\u003e\n\u003ctd\u003eHigh-resolution connected active speaker\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Level\u003c\/td\u003e\n\u003ctd\u003e99 dB RMS mono, 109 dB peak stereo (with two speakers)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e30 Hz to 23 kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMidrange Tweeter\u003c\/td\u003e\n\u003ctd\u003eDOM 45\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWoofers\u003c\/td\u003e\n\u003ctd\u003e2 x 12 cm (4.72 inches) bass drivers in Push Push layout\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eAmplification\u003c\/td\u003e\n\u003ctd\u003e65 watts treble, 76 watts woofer\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eConnectivity\u003c\/td\u003e\n\u003ctd\u003eEthernet, Wi-Fi, Bluetooth, 3.5 mm jack, USB-C, SPDIF optical\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSupported Audio Formats\u003c\/td\u003e\n\u003ctd\u003eMP3, WAV, AAC, WMA, AIFF, FLAC, ALAC, Ogg Vorbis, DSD 64 and 128, WMA Lossless\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eRoom Calibration\u003c\/td\u003e\n\u003ctd\u003eAutomatic room calibration (CRCS) with integrated microphone\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMultiroom\u003c\/td\u003e\n\u003ctd\u003eHigh-resolution multiroom supported via StreamCONTROL app, compatible with AirPlay 2\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eControls\u003c\/td\u003e\n\u003ctd\u003e6 illuminated tactile keys with haptic vibration (source, play pause, volume, power)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBattery Life\u003c\/td\u003e\n\u003ctd\u003eUp to 12 hours\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFinish Options\u003c\/td\u003e\n\u003ctd\u003eMatte black or matte white with chrome accents\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDimensions\u003c\/td\u003e\n\u003ctd\u003e7.3 x 6.9 x 7.1 inches\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWeight\u003c\/td\u003e\n\u003ctd\u003e2.1 kg\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003eWhat’s in the Box\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eCabasse THE PEARL MYUKI speaker\u003c\/li\u003e\n\u003cli\u003eCarrying bag\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Cabasse","offers":[{"title":"Black \/ Standard (Pack of 2)","offer_id":42482007834695,"sku":"ENC1728","price":3299.0,"currency_code":"USD","in_stock":false},{"title":"Black \/ With Wall Mount (Pack of 2)","offer_id":42482007867463,"sku":null,"price":3697.0,"currency_code":"USD","in_stock":false},{"title":"White \/ Standard (Pack of 2)","offer_id":42482007900231,"sku":"ENC1729","price":3299.0,"currency_code":"USD","in_stock":false},{"title":"White \/ With Wall Mount (Pack of 2)","offer_id":42482007932999,"sku":null,"price":3697.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/MYUKI_BLACK_PERSPECTIVE_RIGHT_JPG.jpg?v=1770190258","url":"https:\/\/headphones.com\/products\/cabasse-the-pearl-myuki-active-speaker","provider":"Headphones.com","version":"1.0","type":"link"}
