Bakoon AMP-13r Desktop Headphone Amplifier
Amplifier type
Portability
365-day returns
Bakoon International
The AMP-13R sums up Bakoon’s mastery in every possible way to build a world class compact audio amplifier.
With the latest achievements in circuit designs, our circuit is now reborn and renamed as the JET SATRI Circuit, an ultra fast, wide bandwidth, full discrete design with zero negative feedback. The JET SATRI Circuit is our breakthrough, and it is now more efficient than ever before, with the lowest number of parts and the shortest signal paths. The same control circuit from the AMP-51R and AMP-41 completes the circuit's optimum performance at all times, thanks to automatic voltage and temperature sensing circuit. A 50 High Precision Stepped Attenuator further ensures the highest possible signal purity and channel balance.
The AMP-13R is most likely the slimmest analogue audio amplifier ever developed with this performance. Not only is it slim, nothing is wasted anywhere to make such a complete design that nonetheless achieves the highest possible sound quality and optimal performance. We have concentrated our mechanical engineering ideas and manufacturing capabilities, with the best possible modern day high tech tools, to create the AMP-13R. And it shows just how far we can go.
Simply put, the AMP-13R redefines what is possible in a compact amplifier.
Specification
Maximum Power Output | 25 watts (8 Ω, 1 kHz) / 45 watts (4 Ω, 1 kHz) / 4 watts (60 Ω, 1 kHz) |
Gain | 22.5 dB max. or 7 dB max (Headphone Low) |
Gain Control | MPU Controlled 50 Stepped Attenuator |
Frequency Response | 10 Hz ~ 500 kHz |
Input | 1 SATRI-LINK (BNC), 2 Voltage (RCA) |
Input Impedance | 10 Ω (SATRI-LINK), 10 kΩ (Voltage) |
Output | 5 Way Cardas Binding Post, 1/4" Headphone Out |
User Interface | Encoder with a built in switch, Remote Controller |
Power Consumption | 30 watts (Idle) / 200 watts (Max) |
Dimensions | 230 mm (W) x 230 mm (D) x 55 mm (H) |
Weight | 4.0 kg (net), 5.0 kg (shipping) |
