1 of 8
Austrian Audio
Austrian Audio Hi-X65 Open-Back Headphones
Pre-order More information
Regular price $429
Sale price $429 Regular price $429.00
Cup style
Wearing style
Driver type
365-day returns
Don’t love it? Return it any time in the first year of ownership
Austrian Audio
Regular price $429
Hi-X65 Professional Open-Back Headphones
Austrian Audio Hi-x65 headphones
Delightfully revealing
Austrian Audio created their new Hi-x65 open-back headphones
with mixing and mastering in mind. They’re built to satisfy the need for close, precise listening at these critical stages of the audio production process.
The same qualities that make them great for professional audio production also make them perfect for audiophiles who appreciate hearing every shade of nuance in the music they love.
High Precision meets pure Enjoyment.
Hi-X65 headphones are built around a driver that was first designed with open headphones in mind, and listening to them is like opening a new window on your music. The open-back design brings a natural and spacious sound, giving new clarity to the placement and character of its individual elements.
Hi-X65 headphones provide a high-resolution, precise aural perspective and a critical new tool for professional mixing and mastering.
Made in Austria.
You’ll understand the quality of your new Hi-X65 headphones the moment you take them out of the box, before you’ve even listened to the first note. They feel great in the hand and great on your ears, and the build quality is exceptional, as you would expect. The Hi-X65 headphones are designed, engineered, and manufactured in Austria by a team of passionate experts with long experience in crafting high-quality microphones and headphones for demanding audio professionals.
Of course, the final test of quality is in the listening. Put the headphones on, turn on your music, and experience for yourself the clarity and precision of Hi-X technology in an open-back design. You’ll hear exactly what we mean.
Austrian Audio Hi-x65 Open-back studio monitoring headphones
Key Features
  • High Excursion Driver Technology
    • High precision sound and outstanding low THD @ low frequencies.
  • All metal hinges and bow for maximum durability
    • Ensuring maximum durability and stability
  • 2x Detachable Cable
    • 1x 3m + 1x 1.2m. For replaceability, compact portability and safety from damage.
  • Foldable construction
    • For maximum portability and easy storage
  • Furnished with 3.5mm (1/8 inch) to 6.3mm (1/4 inch) adapter
    • Pro or on-the-go
  • Soft slow retention memory foam earpads
    • Providing greatest comfort during long sessions
High Excursion Technology
Hi-Xcursion (High Excursion) technology is the key to the astonishing sound of our Hi-X65 headphones.
All Austrian Audio Hi-X headphones feature a 44 mm driver and a ring magnet system. This design allows for improved airflow and includes the strongest magnetic field in its class.
The ring magnet, combined with a copper-clad aluminum voice coil, reduces the weight of the membrane and the voice coil connected to it, allowing the membrane to move or change direction faster, providing a more responsive impulse reaction.
Our science, measurements, and listening tests have shown that 44mm is the optimum size for this design. It ensures professional performance in the Hi-X, moves a lot of air, and eliminates ‘wobbling’ of the diaphragm. This is akin to damping of the driver mass, which is where our membrane really shows results: it is ultra-stiff while still reducing unwanted resonance.
Specifications
Title Description
Frequency range: 5 Hz – 28 kHz
THD (@ 1kHz) < 0.1%
Input Power 150 mW
Connector 3.5 mm (1/8”)
Dimensions 200 x 170 x 85 mm
Sensitivity 110 dBspl/V
Impedance 25 Ω
2 Cables (detachable) 3 m + 1.2 m
Adapter (included) 3.5 mm to 6.3 mm (1/8” to 1/4")
Weight (without cable) 310 g
