1 of 13
Austrian Audio
Austrian Audio Hi-x55 Professional Closed-Back Headphones
Pre-order More information
Regular price $349
Sale price $349 Regular price $349.00
Cup style
Wearing style
Driver type
365-day returns
Don’t love it? Return it any time in the first year of ownership
Austrian Audio
Regular price $349
Austrian Audio Hi-x55 Closed-Back headphones
Made in Austria
The engineers at Austrian Audio have designed and produced some of the world’s most acclaimed headphones and drivers. When it came time to create our first family of professional headphones, we took all the time needed to create them and to exceed many of the goals and challenges that came before.
Introducing the new professional Hi-X (High Excursion) headphones from Austrian Audio. Whether you choose the Hi-X50 or Hi-X55, know that you are getting “Made in Austria” quality from a team that stands behind this all-new design. You won’t find off the shelf drivers and key components here – everything is crafted by Austrian Audio right here in Austria.
Austrian Audio Hi-x55 over-ear closed headphones
Key Features
  • High Excursion Driver Technology
    • High precision sound and outstanding low THD @ low frequencies.
  • All metal hinges and bow for maximum durability
    • Ensuring maximum durability and stability
  • 2x Detachable Cable
    • 1x 3m + 1x 1.2m. For replaceability, compact portability and safety from damage.
  • Foldable construction
    • For maximum portability and easy storage
  • Furnished with 3.5mm (1/8 inch) to 6.3mm (1/4 inch) adapter
    • Pro or on-the-go
  • Soft slow retention memory foam earpads
    • Providing greatest comfort during long sessions
hi-x55 headphones
High Excursion Technology
Hi-X
Professional Headphones
Hi-Xcursion (High Excursion) technology is the key to the astonishing sound of our Hi-X55 headphones.
All Austrian Audio Hi-X headphones feature a 44 mm driver and a ring magnet system. This design allows for improved airflow and includes the strongest magnetic field in its class.
The ring magnet, combined with a copper-clad aluminum voice coil, reduces the weight of the membrane and the voice coil connected to it, allowing the membrane to move or change direction faster, providing a more responsive impulse reaction.
Our science, measurements, and listening tests have shown that 44mm is the optimum size for this design. It ensures professional performance in the Hi-X, moves a lot of air, and eliminates ‘wobbling’ of the diaphragm. This is akin to damping of the driver mass, which is where our membrane really shows results: it is ultra-stiff while still reducing unwanted resonance.
