{"product_id":"aune-audio-n7-headphone-amplifier","title":"Aune Audio N7 Headphone Amplifier","description":"\u003cp\u003eThe Aune N7 is a fully discrete Class A headphone amplifier that puts up to 6.5 watts of balanced output into a chassis just over eight inches wide. It borrows the architecture of much larger amplifiers, twin JFET input stage, R2R volume control, and selectable Class A bias current, and makes that recipe fit a desk where space actually matters.\u003c\/p\u003e\n\u003cp\u003eThe N7 is a pure analog amplifier and preamp with no DAC inside: feed it from any DAC or streamer over RCA or balanced XLR and it takes care of everything after the conversion. For listeners stepping up from a dongle or all-in-one to their first serious amplifier, this is the point where Class A stops being exotic and starts being affordable.\u003c\/p\u003e\n\u003ch3\u003eReal Class A, Warm on Purpose\u003c\/h3\u003e\n\u003cp\u003eClass A means the output transistors conduct continuously instead of switching on and off with the signal, which eliminates crossover distortion and keeps the amplifier in its most linear range at all times. The sound this design is known for is smooth, full-bodied, and naturally warm, and the N7 runs true Class A rather than borrowing the label.\u003c\/p\u003e\n\u003cp\u003eThe input stage uses matched twin JFETs packaged together so both devices heat and behave identically, keeping the circuit's midpoint voltage stable and the character consistent. JFETs are the reason the N7 earns its tube-like description: high input impedance and a naturally smooth transfer characteristic, with none of a tube's fragility or maintenance.\u003c\/p\u003e\n\u003ch3\u003eTwo Current Levels, Two Gain Levels, One Quiet Background\u003c\/h3\u003e\n\u003cp\u003eLike Aune's flagship amplifiers, the N7 offers dual-level Class A bias current: A-L for everyday listening and A-H for a fuller, more forceful presentation, shown in blue or red on the display along with real-time temperature. Two gain settings then match the output to the headphone, from sensitive in-ear monitors on low gain to demanding full-size headphones on high.\u003c\/p\u003e\n\u003cp\u003eBehind that flexibility sits a measured noise floor of 3 microvolts in high gain and THD+N below 0.0004% at 1kHz. In practice, IEMs get silence instead of hiss, and hard-to-drive headphones get 6,570mW into 32 ohms or 750mW into 300 ohms from the balanced output. A full aluminum chassis with side heatsink fins keeps sustained Class A operation stable.\u003c\/p\u003e\n\u003ch3\u003eR2R Volume That Stays Balanced at Night\u003c\/h3\u003e\n\u003cp\u003eThe N7 uses two JRC R2R electronic volume chips with dedicated op-amps, forming a four-channel balanced volume chain. Unlike a conventional potentiometer, which loses left-right balance at the bottom of its range, this control stays matched at the low levels where late-night listening actually happens, and it preserves imaging and stage while doing it.\u003c\/p\u003e\n\u003cp\u003eOne multifunctional knob handles volume, gain, current level, and headphone or preamp switching, with a 3-inch display keeping the current state readable from across the desk. An aluminum remote is included, so the N7 works as well from a couch as it does at arm's reach.\u003c\/p\u003e\n\u003ch3\u003eA Preamp for the Rest of the System\u003c\/h3\u003e\n\u003cp\u003eThe N7 offers two headphone outputs (6.35mm single-ended and 4.4mm balanced), two line inputs (RCA and XLR), and two preamp outputs (RCA and XLR), with an independent Class A preamp function. Plug in powered monitors or a power amplifier and it becomes the control center of a compact desktop system, headphones by night, speakers by day.\u003c\/p\u003e\n\u003cp\u003ePower comes from an external 18V adapter, which keeps AC conversion outside the chassis. Component selection follows Aune's desktop line: Panasonic electrolytic capacitors, WIMA decoupling capacitors, and a communication-grade PCB.\u003c\/p\u003e\n\u003ch3\u003eHow the N7 Compares\u003c\/h3\u003e\n\u003cp\u003eThe natural reference point is Aune's own \u003ca href=\"\/products\/aune-audio-s17-pro-evo-headphone-amplifier\" title=\"Aune Audio S17 Pro Balanced Class A Headphone Amplifier | Headphones.com\" rel=\"noopener\" target=\"_blank\"\u003eS17 Pro EVO\u003c\/a\u003e, which shares the same design ideas: twin JFET input, R2R volume, selectable Class A current. The S17 Pro EVO adds a 50W internal toroidal supply, a 4-pin XLR output, and 7.5 watts of balanced power for the hardest planar loads. The N7 delivers most of that architecture at half the price, and at 6.5 watts balanced it still out-muscles nearly everything else near $399. Run your own headphones through our \u003ca href=\"\/pages\/headphones-power-calculator\" title=\"Headphone Power Calculator for calculation exact power needs for your headphones | Headphones.com\" rel=\"noopener\" target=\"_blank\"\u003eheadphone power calculator\u003c\/a\u003e to see how much you actually need.\u003c\/p\u003e\n\u003cp\u003eAune photographs the N7 next to its \u003ca href=\"\/products\/aune-ar5000-mk2-headphones\" title=\"Aune Audio AR5000MK2 Headphones | Headphones.com\" rel=\"noopener\" target=\"_blank\"\u003eAR5000\u003c\/a\u003e open-back for a reason: the pairing makes a complete, warm, spacious desktop rig for well under a thousand dollars. It fits just as readily under any DAC you already own.\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eFully discrete pure Class A headphone amplifier and preamp\u003c\/li\u003e\n\u003cli\u003eUp to 6.5W balanced output (6,570mW into 32 ohms, high gain)\u003c\/li\u003e\n\u003cli\u003eMatched twin JFET input stage for a smooth, tube-like character\u003c\/li\u003e\n\u003cli\u003eDual-level Class A bias current (A-L \/ A-H) with two-color display\u003c\/li\u003e\n\u003cli\u003eTwo gain settings covering sensitive IEMs to full-size headphones\u003c\/li\u003e\n\u003cli\u003e3uV output noise floor in high gain; THD+N below 0.0004% at 1kHz\u003c\/li\u003e\n\u003cli\u003eFour-channel balanced R2R volume control with dual JRC chips\u003c\/li\u003e\n\u003cli\u003e6.35mm single-ended and 4.4mm balanced headphone outputs\u003c\/li\u003e\n\u003cli\u003eRCA and XLR line inputs; RCA and XLR preamp outputs\u003c\/li\u003e\n\u003cli\u003eIndependent Class A preamp function for powered speakers\u003c\/li\u003e\n\u003cli\u003e3-inch display with real-time temperature readout\u003c\/li\u003e\n\u003cli\u003eMultifunctional knob and aluminum remote control\u003c\/li\u003e\n\u003cli\u003eFull aluminum chassis with integrated heatsink fins\u003c\/li\u003e\n\u003cli\u003ePanasonic and WIMA components on a communication-grade PCB\u003c\/li\u003e\n\u003cli\u003eHi-Res Audio certification\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eProduct Type\u003c\/td\u003e\n\u003ctd\u003eClass A headphone amplifier and preamplifier\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eArchitecture\u003c\/td\u003e\n\u003ctd\u003eFully discrete, pure Class A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Stage\u003c\/td\u003e\n\u003ctd\u003eMatched twin JFET\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eClass A Current Modes\u003c\/td\u003e\n\u003ctd\u003eA-L \/ A-H, selectable\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eGain Settings\u003c\/td\u003e\n\u003ctd\u003eLow \/ High\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eVolume Control\u003c\/td\u003e\n\u003ctd\u003eFour-channel balanced R2R, dual JRC chips with dedicated op-amps\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eHeadphone Outputs\u003c\/td\u003e\n\u003ctd\u003e6.35mm single-ended, 4.4mm balanced\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eLine Inputs\u003c\/td\u003e\n\u003ctd\u003eRCA (10K ohm) and XLR (22K ohm)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePreamp Outputs\u003c\/td\u003e\n\u003ctd\u003eRCA (200 ohm) and XLR (100 ohm)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eHeadphone Output Impedance\u003c\/td\u003e\n\u003ctd\u003e1 ohm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Response\u003c\/td\u003e\n\u003ctd\u003e20Hz - 80kHz, +\/-0.05dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD+N\u003c\/td\u003e\n\u003ctd\u003e\u0026lt;0.0004% at 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eOutput Noise\u003c\/td\u003e\n\u003ctd\u003e3uV (high gain)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSNR\u003c\/td\u003e\n\u003ctd\u003e\u0026gt;105dB at 600 ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eCrosstalk\u003c\/td\u003e\n\u003ctd\u003e\u0026lt; -100dB at 1kHz, 600 ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower\u003c\/td\u003e\n\u003ctd\u003eExternal 18V DC adapter\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDisplay\u003c\/td\u003e\n\u003ctd\u003e3-inch display with temperature readout\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDimensions\u003c\/td\u003e\n\u003ctd\u003e208 x 160 x 83mm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eRemote\u003c\/td\u003e\n\u003ctd\u003eAluminum remote control included\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003eHeadphone Output Power (High Gain)\u003c\/h3\u003e\n\u003ctable\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eLoad\u003c\/th\u003e\n\u003cth\u003eSingle-Ended Output\u003c\/th\u003e\n\u003cth\u003eBalanced Output\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e32 ohms\u003c\/td\u003e\n\u003ctd\u003e1,900mW\u003c\/td\u003e\n\u003ctd\u003e6,570mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e100 ohms\u003c\/td\u003e\n\u003ctd\u003e616mW\u003c\/td\u003e\n\u003ctd\u003e2,190mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e150 ohms\u003c\/td\u003e\n\u003ctd\u003e416mW\u003c\/td\u003e\n\u003ctd\u003e1,500mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e250 ohms\u003c\/td\u003e\n\u003ctd\u003e252mW\u003c\/td\u003e\n\u003ctd\u003e900mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e300 ohms\u003c\/td\u003e\n\u003ctd\u003e213mW\u003c\/td\u003e\n\u003ctd\u003e750mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e470 ohms\u003c\/td\u003e\n\u003ctd\u003e136mW\u003c\/td\u003e\n\u003ctd\u003e480mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e600 ohms\u003c\/td\u003e\n\u003ctd\u003e106mW\u003c\/td\u003e\n\u003ctd\u003e370mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003eWhat's in the Box\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eAune N7 headphone amplifier\u003c\/li\u003e\n\u003cli\u003ePower adapter and power cord\u003c\/li\u003e\n\u003cli\u003e6.35mm to 3.5mm adapter\u003c\/li\u003e\n\u003cli\u003eQuick start guide\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Aune Audio","offers":[{"title":"Default Title","offer_id":43019428266055,"sku":"AUNE-N7","price":399.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/0_a9517f97-4770-4cdd-928d-ba314b505640.jpg?v=1785368602","url":"https:\/\/headphones.com\/products\/aune-audio-n7-headphone-amplifier","provider":"Headphones.com","version":"1.0","type":"link"}
