{"product_id":"aune-audio-ar3000-meze-audio-boom-mic-gaming-bundle","title":"Aune Audio AR3000 + Meze Audio Boom Mic Gaming Bundle","description":"\u003ch3\u003eGear Up for the Holidays with the Aune AR3000 + Meze Boom Mic Gaming Bundle\u003c\/h3\u003e\n\u003cp\u003eThe Aune AR3000 + Meze Boom Mic Holiday Gaming Bundle pairs our pick for the best headphone under $250 with a detachable boom microphone, so you get a complete wired gaming headset in one order. It is the low-cost way to bring proper hi-fi sound to your games and a clear voice to your chat.\u003c\/p\u003e\n\u003cp\u003eWe put this bundle together around a simple idea: start with a headphone our reviewers recommend for music, then add a good microphone. The AR3000 brings powerful bass, natural voices and smooth treble to explosions, dialogue and soundtracks. The Meze Audio Boom Mic carries your voice on the same cable, with mute and volume within reach. When the game is over, you still own one of our favorite headphones for music. It also makes an easy holiday gift for the gamer in your life, with everything needed to plug in and play.\u003c\/p\u003e\n\u003ch3\u003eIs This Bundle Right for You?\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eBest for:\u003c\/strong\u003e PC and console gamers who play in a quiet room and want rich, powerful sound and a clear microphone on a sensible budget. It suits you especially well if the same headphones will play your music.\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eThink twice if:\u003c\/strong\u003e You share a room or play somewhere noisy. The AR3000's open earcups let sound travel both ways, and the Boom Mic hears the room as well as your voice. This is also a wired setup.\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eStart with:\u003c\/strong\u003e The 3.5mm headset jack on your controller, laptop or PC. There are no batteries to charge and no amplifier to buy.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003ePowerful Bass and Natural Voices for Games\u003c\/h3\u003e\n\u003cp\u003eThe AR3000 gives games the same things it gives music. Bass has real weight and reaches deep, so an explosion or an engine lands with a thump you can feel. Voices sound natural, which keeps dialogue and your teammates easy to follow, and the treble is smooth enough that a long session does not wear on your ears.\u003c\/p\u003e\n\u003cp\u003eThat sound comes from a 50mm dynamic driver with a titanium-coated diaphragm, light enough to respond quickly and rigid enough to stay controlled. Aune's Tilted Acoustic Matrix angles the drivers and earpads toward your ears, and the open-back earcups let the sound breathe. The result is a natural sense of space that helps you tell where sounds are coming from, and it suits open-world games and cinematic soundtracks well.\u003c\/p\u003e\n\u003ch3\u003eThe Meze Audio Boom Mic\u003c\/h3\u003e\n\u003cp\u003eThe Boom Mic is a headphone cable with a microphone on a flexible arm. It replaces the AR3000's stock cable: its two plugs connect to the earcups, and a single 2.5m cable runs to your controller or computer carrying both game audio and your voice. You bend the arm to put the microphone where you want it.\u003c\/p\u003e\n\u003cp\u003eMeze uses a condenser capsule with an omnidirectional pickup pattern, which captures your voice naturally from any angle, so you do not have to keep the microphone in one exact spot to be heard clearly. The capsule sits in a CNC-milled aluminum housing, and a control clip on the cable has a mute switch and a rotary volume dial. It is the same pairing we use for calls at Headphones.com.\u003c\/p\u003e\n\u003cp\u003eAn omnidirectional microphone also hears the room. Meze recommends a quiet space or noise-cancelling software, such as the noise suppression in your chat app. That is the same advice we would give for an open-back headphone, so if you have a loud keyboard or a busy household, keep it in mind.\u003c\/p\u003e\n\u003ch3\u003ePC, PlayStation, Xbox and Switch\u003c\/h3\u003e\n\u003cp\u003eThe Boom Mic ends in a single 3.5mm plug wired to the CTIA standard, the layout used by headset jacks that carry audio and microphone together. Meze lists PlayStation 5, PlayStation 4, Xbox Series X and S, Xbox One and Nintendo Switch as compatible, along with PCs, laptops, tablets and phones that have a 3.5mm jack. For a desktop PC with separate headphone and microphone sockets, the included Y-adapter splits the plug in two.\u003c\/p\u003e\n\u003cp\u003eThe AR3000 does its part by being easy to drive. At 27 ohms with a sensitivity of 115dB SPL at 1Vrms, it does not need a separate amplifier, so the jack you already have is the place to start. The Boom Mic's 2.5m cable is a full meter longer than the AR3000's own 1.5m cables, which gives you room to move at a desk.\u003c\/p\u003e\n\u003ch3\u003eComfortable for Long Sessions\u003c\/h3\u003e\n\u003cp\u003eAt approximately 300g, the AR3000 keeps the load manageable for long sessions. Its breathable memory-foam earpads rotate to follow the angle of your ears, and the suspension strap can sit forward or back until you find a comfortable resting point.\u003c\/p\u003e\n\u003cp\u003eBecause the earcups are open, you hear your own voice normally when you talk, and you can still hear the doorbell or someone calling from the next room. The same openness means people nearby will hear some of your game, so this is a setup for a room of your own.\u003c\/p\u003e\n\u003ch3\u003eMusic with the AR3000\u003c\/h3\u003e\n\u003cp\u003eUnplug the Boom Mic and the AR3000 goes back to being the headphone our reviewers recommend for music. Both of Aune's cables are in the box, one with a 3.5mm plug and one with a 4.4mm balanced plug, along with a 6.35mm adapter. That is the main reason to buy a headphone and a microphone instead of a headset: the headphone is good enough to keep using for everything else.\u003c\/p\u003e\n\u003ch3\u003eHow the Bundle Compares\u003c\/h3\u003e\n\u003cp\u003eIn the same price range, the \u003ca href=\"\/products\/audeze-maxwell-2-wireless-gaming-headphones\" title=\"Audeze Maxwell 2 Wireless Gaming Headphones\" rel=\"noopener\" target=\"_blank\"\u003eAudeze Maxwell 2\u003c\/a\u003e is the gaming headset to look at if you need wireless or a closed-back design that blocks out a noisy room. This bundle goes the other way. It is wired and open-back, built for a quiet room, and at roughly 300g the AR3000 is a little over half the Maxwell 2's 560g.\u003c\/p\u003e\n\u003cp\u003eAt $328, the bundle is priced at the AR3000 and the Boom Mic combined, and it gets you a headphone and microphone we already know work well together in a single order. That is a low price for a headset built around our favorite headphone under $250. If you already own an \u003ca href=\"\/products\/aune-audio-ar3000-headphones\" title=\"Aune Audio AR3000 Open-Back Headphones\" rel=\"noopener\" target=\"_blank\"\u003eAR3000\u003c\/a\u003e, the \u003ca href=\"\/products\/meze-audio-boom-mic\" title=\"Meze Audio Boom Mic\" rel=\"noopener\" target=\"_blank\"\u003eMeze Audio Boom Mic\u003c\/a\u003e is available on its own.\u003c\/p\u003e\n\u003ch3\u003eThe Headphone Show Reviews the AR3000\u003c\/h3\u003e\n\u003cp\u003eAfter listening to the production AR3000, Andrew Park (Resolve), Cameron Oatley (GoldenSound) and Griffin Silver (listener) all praised how hard its bass hits and how natural it sounds, and none of them found it harsh or fatiguing. Their written verdict calls it one of the easiest, most universal recommendations they have made. In a separate review, Caleb Loo (FC-Construct) names the price as its greatest strength and says it competes with headphones at multiple times the cost.\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"\/blogs\/reviews\/the-hd-6xx-replacement-aune-ar3000-review\" title=\"The HD 6XX Replacement: Aune AR3000 Review\" rel=\"noopener\" target=\"_blank\"\u003eRead the Aune AR3000 review\u003c\/a\u003e, \u003ca href=\"https:\/\/www.youtube.com\/watch?v=0dtmWgRgIVA\" title=\"The Headphone Show: Aune AR3000 review\" rel=\"noopener\" target=\"_blank\"\u003ewatch the video\u003c\/a\u003e or \u003ca href=\"\/blogs\/reviews\/aune-ar3000-review-the-new-de-facto\" title=\"Aune AR3000 Review: The New De Facto, by Caleb Loo\" rel=\"noopener\" target=\"_blank\"\u003eread Caleb's review\u003c\/a\u003e. \u003csmall\u003e(Reviews of the AR3000 as a music headphone; paraphrased above.)\u003c\/small\u003e\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eAune Audio AR3000 open-back headphones, our pick for the best headphone under $250\u003c\/li\u003e\n\u003cli\u003eMeze Audio Boom Mic with a condenser capsule on a flexible arm\u003c\/li\u003e\n\u003cli\u003eOne 2.5m cable carries game audio and your voice\u003c\/li\u003e\n\u003cli\u003eIn-line mute switch and rotary volume control\u003c\/li\u003e\n\u003cli\u003e3.5mm CTIA plug for controller, laptop and PC headset jacks\u003c\/li\u003e\n\u003cli\u003eY-adapter included for PCs with separate headphone and microphone sockets\u003c\/li\u003e\n\u003cli\u003e50mm dynamic driver with a titanium-coated diaphragm\u003c\/li\u003e\n\u003cli\u003eTilted Acoustic Matrix with an angled baffle and tilted earpads\u003c\/li\u003e\n\u003cli\u003e27 ohms and 115dB SPL at 1Vrms, so no separate amplifier is needed\u003c\/li\u003e\n\u003cli\u003eApproximately 300g, with breathable memory-foam earpads and a suspension strap\u003c\/li\u003e\n\u003cli\u003eCNC-milled, laser-engraved aluminum microphone housing\u003c\/li\u003e\n\u003cli\u003eNo batteries to charge and nothing to install\u003c\/li\u003e\n\u003cli\u003eThe AR3000's own 3.5mm and 4.4mm balanced cables included for music\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eBundle Contents\u003c\/th\u003e\n\u003ctd\u003eAune Audio AR3000 headphones and Meze Audio Boom Mic\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eHeadphone Type\u003c\/th\u003e\n\u003ctd\u003eWired, over-ear, open-back\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eDriver\u003c\/th\u003e\n\u003ctd\u003e50mm dynamic, titanium-coated diaphragm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eFrequency Range\u003c\/th\u003e\n\u003ctd\u003e5Hz - 40,000Hz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eNominal Impedance\u003c\/th\u003e\n\u003ctd\u003e27 ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eSensitivity\u003c\/th\u003e\n\u003ctd\u003e115dB SPL at 1kHz\/1Vrms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eTHD\u003c\/th\u003e\n\u003ctd\u003e\u0026lt;0.1% at 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eHeadphone Weight\u003c\/th\u003e\n\u003ctd\u003eApprox. 300g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eMicrophone Type\u003c\/th\u003e\n\u003ctd\u003eCondenser\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003ePolar Pattern\u003c\/th\u003e\n\u003ctd\u003eOmnidirectional\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eMicrophone Sensitivity\u003c\/th\u003e\n\u003ctd\u003e-44dB (+\/-3dB)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eMicrophone Frequency Response\u003c\/th\u003e\n\u003ctd\u003e100Hz - 10,000Hz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eBoom Mic Cable Length\u003c\/th\u003e\n\u003ctd\u003e2.5m \/ 8.2ft\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eBoom Mic Source Plug\u003c\/th\u003e\n\u003ctd\u003e3.5mm, CTIA; Y-adapter included for separate headphone and microphone sockets\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eIn-Line Controls\u003c\/th\u003e\n\u003ctd\u003eMute switch and rotary volume control\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003cth scope=\"row\"\u003eAR3000 Music Cables\u003c\/th\u003e\n\u003ctd\u003eTwo 1.5m oxygen-free copper cables: 3.5mm single-ended and 4.4mm balanced, with a 6.35mm adapter\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003eWhat's Included\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eAune Audio AR3000 headphones\u003c\/li\u003e\n\u003cli\u003e1.5m OFC cable with 3.5mm single-ended source plug\u003c\/li\u003e\n\u003cli\u003e1.5m OFC cable with 4.4mm balanced source plug\u003c\/li\u003e\n\u003cli\u003e3.5mm-to-6.35mm adapter\u003c\/li\u003e\n\u003cli\u003eAR3000 quick start guide\u003c\/li\u003e\n\u003cli\u003eMeze Audio Boom Mic\u003c\/li\u003e\n\u003cli\u003e3.5mm Y-adapter\u003c\/li\u003e\n\u003cli\u003ePU leather pouch for the Boom Mic\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eBundle Questions\u003c\/h3\u003e\n\u003cp\u003e\u003cstrong\u003eDoes the Boom Mic fit the AR3000?\u003c\/strong\u003e\u003cbr\u003eYes. The Boom Mic is made for headphones with two 3.5mm cable sockets, one on each earcup, which is how the AR3000 connects. It plugs in where the stock cable does.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eWill it work with my PlayStation, Xbox or Switch?\u003c\/strong\u003e\u003cbr\u003eYes, through the 3.5mm headset jack on the controller or console. Meze lists PlayStation 5, PlayStation 4, Xbox Series X and S, Xbox One and Nintendo Switch as compatible sources.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eDo I need an amplifier, a DAC or software?\u003c\/strong\u003e\u003cbr\u003eNo. The AR3000 is efficient enough for an ordinary headphone jack, and the Boom Mic is an analog microphone with no batteries and nothing to install. If your PC has separate headphone and microphone sockets, use the included Y-adapter.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eIs it a good choice for competitive shooters?\u003c\/strong\u003e\u003cbr\u003eIt places sounds clearly enough for everyday play, and its real strengths are tone, bass and comfort. In \u003ca href=\"https:\/\/headphones.com\/blogs\/reviews\/aune-ar3000-review-the-new-de-facto\" title=\"Aune AR3000 Written Review by FC-Construct | Headphones.com\" rel=\"noopener\" target=\"_blank\"\u003ehis review\u003c\/a\u003e, Caleb Loo (FC-Construct) found the AR3000's soundstage and imaging about average for an open-back headphone. Think of it as a great-sounding all-rounder; if pinpoint positioning is your only priority, a headset designed around it will serve you better.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eCan people nearby hear my game?\u003c\/strong\u003e\u003cbr\u003eYes. The AR3000 is open-back, so some sound escapes and outside noise comes in. It is at its best in a room of your own.\u003c\/p\u003e","brand":"Aune Audio","offers":[{"title":"Default Title","offer_id":50177125711943,"sku":"AR-3000-MZB","price":328.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/01-aune-ar3000-meze-boom-mic-gaming-bundle.jpg?v=1794932230","url":"https:\/\/headphones.com\/products\/aune-audio-ar3000-meze-audio-boom-mic-gaming-bundle","provider":"Headphones.com","version":"1.0","type":"link"}
