Audio-Technica ATH-M50x Studio Monitors (WHITE)
Cup style
Wearing style
Driver type
365-day returns
Audio-Technica
Widely acclaimed for their sonic performance, one-ear monitoring capability, and foldable, travel-friendly design, the white Audio-Technica ATH-M50x M-Series monitor headphones offer pro-grade build quality and audio performance for professional studio-based production, location recording, DJing, podcasting, and daily listening. Outfitted with 45mm large-aperture dynamic drivers and an over-ear, closed-back design, the ATH-M50x headphones deliver clarity, deep bass, and extended bandwidth (15 Hz to 28 kHz) while isolating you from outside sounds.
Thanks to the 90° swivelling ear cups, pro-quality materials, and generous cushioning on the headband and ear pads, the headphones are both durable and comfortable to wear. Three detachable, single-sided cables—one coiled and two straight—are included for optimal operation in the studio or on the go. Each cable sports a gold-plated 3.5mm mini plug for use with mobile devices and computer soundcards, and a 1/4" screw-on adapter is included for easy hookup to audio interfaces, mixers, and stereo receivers. A carrying pouch is supplied with the ATH-M50x for convenient storage and transport of the headphones.
45mm Drivers
Tuned for Clarity and Deep, Accurate Bass
Over-Ear, Sound-Isolating Design
90° Swivelling Ear cups and Foldable Design
Three Detachable Single-Sided Cables
3.5mm Plug and 1/4" Screw-On Adapter
Pro-Grade Build Quality
In the Box
- Audio-Technica ATH-M50x Closed-Back Monitor Headphones (White)
- Coiled Cable (3.9 to 9.8')
- Straight Cable (9.8')
- Straight Cable (3.9')
- 1/4" Screw-On Adapter
- Carrying Pouch
- Limited 2-Year Warranty
Tech Specs
Headphone
Earpiece Design | Over-Ear (Circumaural), Closed-Back |
Earpiece Swivel | Yes, 90° |
Earpiece Connection / Wearing Style | Headband |
Foldable | Yes |
Driver Type | Dynamic |
Driver Size | 1.8" / 45 mm |
Magnet Type | Neodymium |
Voice Coil | Copper-Clad Aluminum Wire |
Impedance | 38 Ohms |
Active Noise Cancellation | No |
Performance
Frequency Response | 15 Hz to 28 kHz |
Sensitivity | 99 dB |
Maximum Power Handling | 1600 mW |
Wired Connectivity
Audio Connector to Source | 1 x 1/8" / 3.5 mm TRS Male Straight |
Connector Plating | Gold |
Adapter (Included) | 1/4" TRS |
Cable Design | Single-Sided, Detachable |
Audio Connector to Earpiece | 1 x 2.5 mm TRS Male |
Cable Length | 3.9 to 9.8' / 1.2 to 3 m 3.9 to 9.8' / 1.2 to 3 m 3.9 to 3.9' / 1.2 to 1.2 m |
Cable Color | Black |
Physical
Color | Black |
Weight | 10 oz / 284 g (without Cable) |
Packaging Info
Package Weight | 2.25 lb |
Box Dimensions (LxWxH) | 11.6 x 10.3 x 4.2" |
