Audio-Technica ATH-ADX5000 - Open-Box
Cup style
Wearing style
Driver type
Amp required
Audio-Technica
The result of Japanese craftsmanship and expert engineering, the Audio-Technica ATH-ADX5000 Hi-Res Audio headphones have set a new standard in open-back headphone performance. The headphones utilize newly developed Core Mount Technology that optimally positions the driver unit within the housing to improve airflow efficiency. The efficient airflow helps the headphones reproduce highly transparent mid and high frequencies and rich, precise bass sound. The 58 mm integrated driver units combine a tungsten-coated diaphragm, baffle and Permendur magnetic circuit in a single unit to reduce unwanted vibration and, since no screw clamps are required, decrease the weight. The baffle is made of a highly-rigid polyphenylene sulfide (PPS)/glass fiber composite to provide stable diaphragm movement.
The housings of the ATH-ADX5000 have a honeycomb-punched design that keeps the housing face open to ventilation, while closing off the sides. This design delivers an accurate, natural sound, but prevents air pressure loss that can negatively affect sound quality. The frame is constructed of strong, lightweight magnesium; the earpads and headband are fashioned from Alcantara, a material known for its extreme durability and comfort.
The ATH-ADX5000 headphones come with a detachable 3.0 m (9.8') cable with A2DC (Audio Designed Detachable Coaxial) connectors at the headphones and a 6.3 mm (1/4") gold-plated stereo plug for connecting to devices. Each pair of headphones is individually identified by a laser etched serial number and comes with a specially designed hard carrying case.
