{"product_id":"audeze-mm-520-headphones","title":"Audeze MM-520 Headphones","description":"\u003cp\u003eThe Audeze MM-520 is a purpose-built open-back planar magnetic headphone for recording, mixing, and serious reference listening. Developed as the next evolution of Audeze’s Manny Marroquin Signature Series, the MM-520 builds on the MM-500 with deeper bass definition, tighter low-end control, more accurate midrange expression, and upgraded comfort for long studio sessions.\u003c\/p\u003e\n\n\u003cp\u003eDesigned in collaboration with 18-time Grammy-winning engineer Manny Marroquin, the MM-520 is made for one thing above all else: translation. It gives engineers and creators a reliable monitoring tool that can move from the studio to a laptop, interface, console, or travel rig while keeping the mix honest. The result is a headphone that feels focused, direct, and dependable, whether you are balancing low end, shaping vocals, checking automation, or making final decisions away from your main monitors.\u003c\/p\u003e\n\n\u003cblockquote\u003e\n  \u003cp\u003e“The MM-520 is more focused overall. Everything translates a little easier, just more dialed in.”\u003c\/p\u003e\n  \u003cp\u003e\u003cstrong\u003eManny Marroquin\u003c\/strong\u003e\u003cbr\u003e18-Time Grammy-Winning Producer\/Engineer\u003c\/p\u003e\n\u003c\/blockquote\u003e\n\n\u003ch3\u003eA Signature Tool for Mixing\u003c\/h3\u003e\n\n\u003cp\u003eThe MM-520 was built for the daily reality of studio work. It is revealing enough for deep listening, fast enough for detailed editing, and practical enough to use outside a fully treated room. Audeze’s planar magnetic driver platform gives the MM-520 the speed and low distortion needed for precise decisions, while its tuning keeps the midrange clear and trustworthy.\u003c\/p\u003e\n\n\u003cp\u003eThat matters most where mixes live or die. Vocals need to sit correctly. Kick and bass need to lock without getting bloated. Reverb and delay tails need to be easy to place. The MM-520 gives you a more confident read on those decisions, with the kind of low-end definition and midrange focus that helps work translate across speakers, headphones, cars, earbuds, and real-world playback systems.\u003c\/p\u003e\n\n\u003ch3\u003eSLAM Technology for Tighter Bass and Better Space\u003c\/h3\u003e\n\n\u003cp\u003eThe biggest acoustic upgrade in the MM-520 is Audeze’s SLAM™ technology, short for Symmetric Linear Acoustic Modulator. SLAM is designed to manage air pressure inside the earcup, helping improve low-frequency impact, bass accuracy, and spatial transparency without sacrificing the midrange neutrality that made the MM-Series a studio staple.\u003c\/p\u003e\n\n\u003cp\u003eThe effect is a more physical, more controlled low end. Bass digs deeper and hits with better shape, but it stays useful for mix decisions rather than turning into extra hype. The MM-520 gives engineers more confidence when judging kick weight, bass guitar density, synth low end, and the space around those elements.\u003c\/p\u003e\n\n\u003ch3\u003ePlanar Precision from Audeze\u003c\/h3\u003e\n\n\u003cp\u003eThe MM-520 uses 90mm planar magnetic drivers with Audeze’s Fluxor™ magnet array, Ultra-Thin Uniforce™ diaphragm, Fazor™ phase management, and SLAM acoustic management. This driver system is built for low distortion, fast transient response, and clean detail across the frequency range.\u003c\/p\u003e\n\n\u003cp\u003eWith a 5Hz to 50kHz frequency response, maximum SPL above 130dB, and THD below 0.1% at 100dB SPL, the MM-520 has the technical headroom needed for demanding professional work. It can stay composed when mixes get dense, while still making small EQ moves, compression changes, and panning decisions easier to hear.\u003c\/p\u003e\n\n\u003ch3\u003eStudio-Quality Sound, Anywhere\u003c\/h3\u003e\n\n\u003cp\u003eThe MM-520 is easier to integrate into a working setup than many high-end planar magnetic headphones. With 18 ohms impedance, 102dB\/1mW sensitivity, and a minimum recommended power requirement above 100mW, it can be driven by audio interfaces, consoles, laptops, portable DAC\/amps, and dedicated headphone amplifiers.\u003c\/p\u003e\n\n\u003cp\u003eThat makes it useful as a studio reference and as a travel-ready monitoring tool. You can use it at the desk, take it to a session, check a mix away from your main room, or keep it close when you need a reference you can trust outside the studio.\u003c\/p\u003e\n\n\u003ch3\u003eComfort and Convenience for Long Sessions\u003c\/h3\u003e\n\n\u003cp\u003eThe MM-520 is designed for marathon mixing sessions, with upgraded memory foam earpads that improve comfort during long hours of focused listening. The pads attach magnetically, making cleaning, maintenance, and replacement easier.\u003c\/p\u003e\n\n\u003cp\u003eThe over-ear open-back design gives the MM-520 a spacious, natural presentation while helping reduce the closed-in feeling that can make long headphone sessions fatiguing. It is a serious studio headphone, but one built to be used for full workdays, not just quick checks.\u003c\/p\u003e\n\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eManny Marroquin Signature Series professional open-back headphone\u003c\/li\u003e\n  \u003cli\u003eDesigned for recording, mixing, deep listening, and mix translation\u003c\/li\u003e\n  \u003cli\u003eBuilt on the award-winning MM-500 foundation\u003c\/li\u003e\n  \u003cli\u003eAudeze SLAM™ acoustic technology for tighter bass and improved spatial detail\u003c\/li\u003e\n  \u003cli\u003e90mm planar magnetic drivers\u003c\/li\u003e\n  \u003cli\u003eFluxor™ magnet array\u003c\/li\u003e\n  \u003cli\u003eUltra-Thin Uniforce™ diaphragm\u003c\/li\u003e\n  \u003cli\u003eFazor™ phase management\u003c\/li\u003e\n  \u003cli\u003eLow distortion performance rated below 0.1% at 100dB SPL, 1kHz\u003c\/li\u003e\n  \u003cli\u003e5Hz to 50kHz frequency response\u003c\/li\u003e\n  \u003cli\u003e102dB\/1mW sensitivity at Drum Reference Point\u003c\/li\u003e\n  \u003cli\u003e18 ohms impedance for easy pairing with studio and portable gear\u003c\/li\u003e\n  \u003cli\u003eMinimum recommended power above 100mW\u003c\/li\u003e\n  \u003cli\u003eUpgraded memory foam earpads for long-session comfort\u003c\/li\u003e\n  \u003cli\u003eMagnetic earpad attachment for easy maintenance and replacement\u003c\/li\u003e\n  \u003cli\u003eIncludes travel case and MM-Series soft carry bag\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width:100%; border-collapse:collapse;\"\u003e\n  \u003ctbody\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eStyle\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eOver-ear, circumaural, open-back\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eTransducer Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003ePlanar magnetic\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMagnetic Structure\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eFluxor™ magnet array\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePhase Management\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eFazor™\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eAcoustic Management\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eSLAM™\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMagnet Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eNeodymium N50\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDiaphragm Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eUltra-Thin Uniforce™\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eTransducer Size\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e90mm\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMaximum SPL\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u0026gt;130dB\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eFrequency Response\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e5Hz to 50kHz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eTHD\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u0026lt;0.1% at 100dB SPL, 1kHz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eSensitivity\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e102dB\/1mW at Drum Reference Point\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eImpedance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e18 ohms\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMinimum Power Requirement\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u0026gt;100mW\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMaximum Power Handling\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e5W RMS\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eWeight\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e555g\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eShipping Weight\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e6 lbs\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePackage Dimensions\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e16 L x 14 H x 8 W in\u003c\/td\u003e\n    \u003c\/tr\u003e\n  \u003c\/tbody\u003e\n\u003c\/table\u003e\n\n\u003ch3\u003eWhat’s in the Box\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eAudeze MM-520 headphone\u003c\/li\u003e\n  \u003cli\u003e2.5m \/ 8.2ft headphone cable\u003c\/li\u003e\n  \u003cli\u003e3.5mm to 6.3mm adapter\u003c\/li\u003e\n  \u003cli\u003eStandard travel case\u003c\/li\u003e\n  \u003cli\u003eMM-Series soft carry bag\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Audeze","offers":[{"title":"Default Title","offer_id":42842242121799,"sku":"100-MM-1032-01","price":1699.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/Audeze_MM-520_Gallery_3_QTR_Angle_RT.jpg?v=1780509936","url":"https:\/\/headphones.com\/products\/audeze-mm-520-headphones","provider":"Headphones.com","version":"1.0","type":"link"}
