{"product_id":"audeze-maxwell-2-wireless-gaming-headphones-open-box","title":"Audeze Maxwell 2 Wireless Gaming Headphones - Open Box","description":"\u003cp\u003eThe Audeze Maxwell 2 takes everything that made the original Maxwell a standout and pushes it further. With upgraded planar magnetic drivers, improved comfort, smarter microphone processing, and new customization options, Maxwell 2 delivers reference-level audio performance in a wireless gaming headset built for serious play.\u003c\/p\u003e\n\u003ch3\u003eGaming, Uncompromised\u003c\/h3\u003e\n\u003cp\u003eMaxwell 2 is designed for players who want top-tier audio without sacrificing wireless convenience. The new 90mm planar magnetic drivers deliver massive scale, pinpoint imaging, and studio-grade clarity that makes footsteps, reloads, and environmental cues feel lifelike and precise.\u003c\/p\u003e\n\u003ch3\u003ePlanar Magnetic Power\u003c\/h3\u003e\n\u003cp\u003eAt the heart of Maxwell 2 are Audeze’s largest gaming planar drivers ever. The 90mm transducers use Fluxor magnet arrays, Fazor phase management, Uniforce diaphragms, and SLAM acoustic tuning to produce deep, controlled bass, clean mids, and extended treble without distortion or fatigue.\u003c\/p\u003e\n\u003ch3\u003eUltra Low Latency Wireless\u003c\/h3\u003e\n\u003cp\u003eMaxwell 2 delivers lag-free, high resolution wireless audio up to 24-bit\/96kHz using its USB-C wireless dongle. Whether you are gaming competitively or streaming media, audio stays perfectly in sync with what you see on screen.\u003c\/p\u003e\n\u003ch3\u003eComfort, Reimagined\u003c\/h3\u003e\n\u003cp\u003eBuilt for long sessions, Maxwell 2 features a redesigned wide ventilated head strap and upgraded ear pads with more internal space. The result is better weight distribution, improved airflow, and all-day comfort for a wider range of head shapes and sizes.\u003c\/p\u003e\n\u003ch3\u003eAI Powered Microphones\u003c\/h3\u003e\n\u003cp\u003eAdvanced FILTER AI noise removal ensures your voice stays clear and natural on chat and stream. Background noise is intelligently removed at the push of a button, while the detachable hypercardioid boom mic delivers focused voice pickup when precision matters most.\u003c\/p\u003e\n\u003ch3\u003eVersatile Connectivity\u003c\/h3\u003e\n\u003cp\u003eMaxwell 2 works seamlessly across platforms with USB-C wireless, USB-C wired audio, Bluetooth, and 3.5mm analog support. Bluetooth includes support for Auracast, LE Audio, LDAC, AAC, and multipoint, making it easy to switch between gaming, music, and calls.\u003c\/p\u003e\n\u003ch3\u003eThe New Audeze App\u003c\/h3\u003e\n\u003cp\u003eA completely redesigned Audeze app gives you fast access to EQ, mic controls, sidetone, and device settings. Available on Windows, macOS, iOS, and Android, the app offers a clean, modern interface built for quick adjustments.\u003c\/p\u003e\n\u003ch3\u003eReSkin Customization\u003c\/h3\u003e\n\u003cp\u003eMaxwell 2 introduces the new ReSkin system, allowing you to swap magnetic side plates to customize the look of your headset. Limited edition designs and collaborations are planned, with more options coming soon.\u003c\/p\u003e\n\u003cp\u003e\u003cmeta charset=\"utf-8\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0023\/9255\/5595\/files\/audeze-maxwell-2-connections.webp?v=1767644187\" alt=\"Audeze Maxwell 2 headphones versatile connectivity options\"\u003e\u003c\/p\u003e\n\u003ch3\u003ePlatform Compatibility\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003ePC and Mac with ultra-low latency wireless, USB-C audio, 3.5mm analog, Dolby Atmos, game and chat mix\u003c\/li\u003e\n\u003cli\u003eXbox with ultra-low latency wireless, 3.5mm analog, Dolby Atmos, game and chat mix\u003c\/li\u003e\n\u003cli\u003ePlayStation with ultra-low latency wireless, USB-C audio, 3.5mm analog, Tempest 3D\u003c\/li\u003e\n\u003cli\u003eSwitch 2 with ultra-low latency wireless, Bluetooth audio, USB-C audio, 3.5mm analog\u003c\/li\u003e\n\u003cli\u003eiOS and Android with Bluetooth, USB-C audio, 3.5mm analog, and app support\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eIn the Box\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eMaxwell 2 headset\u003c\/li\u003e\n\u003cli\u003eDetachable boom microphone with pop filter\u003c\/li\u003e\n\u003cli\u003eUSB-C wireless dongle\u003c\/li\u003e\n\u003cli\u003eUSB-C to USB-C cable (1.5m)\u003c\/li\u003e\n\u003cli\u003eUSB-C to USB-A adapter cable (0.3m)\u003c\/li\u003e\n\u003cli\u003e3.5mm TRRS analog cable (1.2m)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specifications\u003c\/h3\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eDesign\u003c\/td\u003e\n\u003ctd\u003eOver-ear, closed-back\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDriver Type\u003c\/td\u003e\n\u003ctd\u003ePlanar Magnetic\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDriver Size\u003c\/td\u003e\n\u003ctd\u003e90 mm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Response\u003c\/td\u003e\n\u003ctd\u003e10Hz to 50kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMaximum SPL\u003c\/td\u003e\n\u003ctd\u003eGreater than 115dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTotal Harmonic Distortion\u003c\/td\u003e\n\u003ctd\u003eLess than 0.1 percent at 100dB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWeight\u003c\/td\u003e\n\u003ctd\u003e560g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBattery Life\u003c\/td\u003e\n\u003ctd\u003eOver 80 hours wireless playback\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFast Charging\u003c\/td\u003e\n\u003ctd\u003e20 minutes for up to 24 hours playback\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWireless\u003c\/td\u003e\n\u003ctd\u003eUSB-C ultra-low latency, Bluetooth 5.3\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBluetooth Codecs\u003c\/td\u003e\n\u003ctd\u003eAuracast, LE Audio, LC3, LC3plus, LDAC, AAC, SBC\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWired Connections\u003c\/td\u003e\n\u003ctd\u003eUSB-C digital, 3.5mm TRRS analog\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMicrophones\u003c\/td\u003e\n\u003ctd\u003eDetachable hypercardioid boom mic, internal beamforming mic\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Audeze","offers":[{"title":"Playstation","offer_id":42872205606983,"sku":"AU-MAXWELL-2-P-OPEN","price":279.0,"currency_code":"USD","in_stock":true},{"title":"Xbox","offer_id":42872205639751,"sku":"AU-MAXWELL-2-X-OPEN","price":299.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/AudezeMaxwell2.jpg?v=1767662841","url":"https:\/\/headphones.com\/products\/audeze-maxwell-2-wireless-gaming-headphones-open-box","provider":"Headphones.com","version":"1.0","type":"link"}
