1 of 12
Astell&Kern
Astell&Kern AK UW100 True Wireless Headphones
Regular price $299
Sale price $299 Regular price
Balanced Armature
Wireless
365-day returns
Astell&Kern
Regular price $299
Tesla Technology, Further Refined
True Wireless Sound
  • High Performance 32-bit DAC
  • Best-in-Class Passive Noise Isolation (PNI)
  • Knowles BA Driver
  • aptX™ Adaptive for High Quality Wireless Audio
  • Ambient Mode
  • Premium Tier QCC5141 & Bluetooth 5.2
  • All Day Music (Total 24hrs playback)
  • Supports Wireless Charge and Fast Charge
Uncompromised Hi-Fi Quality. No Cables Required.
Astell&Kern's long-standing, fundamental principle is the reproduction of sound as true to the original source as possible.
The AK UW100, Astell&Kern's first fully wireless earphone, based on our proprietary audio technology, provides uncompromising wireless Hi-Fi sound with no cables required.
A rarity for True Wireless Stereo (TWS*), the AK UW100 has a separate embedded high-performance 32-bit DAC as well as a Balanced Armature driver for accurately reproducing sound, allowing the delivery of precise, high-quality audio with no loss of detail.
aptX Adaptive audio codec support for exceptional audio quality is the final flourish, ensuring the AK UW100 is ready for wireless Hi-Fi sound.
Combining all these features with ergonomic design and best-in-class Passive Noise Isolation (PNI), the AK UW100 takes your listening experience to a dimension where only you and the artist exist.
*TWS (True Wireless Stereo) products use Bluetooth to connect to earbuds. No cables are required.
A New Benchmark for Wireless Audio
True Wireless Stereo has long been a focus of our product development. For us TWS ultimately is a means of giving people the freedom to enjoy their music.
The AK UW100 is the result of Astell&Kern's uncompromising dedication to authentically replicating the original sound even in the challenging wireless environment, as well as our laser focus on the essentials of audio transmission.
Digital signals are inaudible, so the DAC converts them into audible analog signals. In the case of many generic TWS systems, the DAC is integrated with the BT chipset, meaning that the focus is on lower power consumption rather than better sound quality, and that they have inherent physical limits when it comes to improving sound quality.
On the other hand, by combining the unique amplifier and audio circuit technology from A&K’s digital audio players with the AK4332, a 32-bit Hi-Fi DAC, the AK UW100 reproduces sound on a whole new level compared to the BT-chipset-integrated DAC. Moreover, it enables clearer and more accurate sound reproduction in all genres by adopting the Knowles Balanced Armature Driver, which is typically used in expensive IEM (in ear monitor) systems, instead of the Dynamic Drivers that are common in generic TWS systems.
The AK UW100 delivers the best wireless Hi-Fi audio you have ever experienced.
AK UW100 Audio Circuit Compared to Conventional TWS Models
Total Music Immersion
The AK UW100 uses best-in-class Passive Noise Isolation (PNI) to immerse you completely in the music.
ANC is not essential to achieve both reduced ambient noise and increased musical focus. When combined with the thoroughly tried-and-tested ergonomic design of the AK UW100, PNI is sufficient to reduce noise physically.
Unlike generic ANC, which concentrates on cancelling low-frequency noise, PNI can efficiently cancel unwanted ambient noise in the mid and high ranges, as well as higher-pitched sounds. Notably, the AK UW100’s noise cancelling capability is comparable to that of ANC, even for low frequencies. Another significant feature is that sound quality is retained, since noise is attenuated by the structure of the earbuds rather than by software. Developed with the help of countless simulations, the AK UW100's best-in-class PNI capability allows you to escape annoying ambient noise and to immerse yourself in an experience where only you and the artist exist.
If you wish to hear ambient sounds, just tap the left earbud once to activate ambient mode. You can switch between the four ambient modes by tapping or using the app.
*Based on the highest frequency band at each of the low (20–100 Hz), mid-to-low (100–500 Hz) and mid (500 Hz–2 kHz) rangesThe measured values of each model are compared based on the measurement site data.Actual measurements may differ depending on the way the product is worn or measured.Actual measurements may differ depending on the ANC implementation method (FF, FB) of the comparative model.The ANC maximum performance frequency band of the comparative model may differ from those presented above.
Premium Bluetooth, Ideal for Hi-Fi Sound Quality
AK UW100 features powerful wireless performance enabled by Premium Tier QCC5141, support for aptX™ Adaptive, Qualcomm's next-generation high-quality codec for wireless 24-bit sound quality and Bluetooth 5.2 support, for better connectivity than previous models.
In particular, through aptX™ Adaptive support, latency — the downside of Bluetooth audio — has been significantly improved.  It also provides a feature that adjusts the bit rate according to the content or wireless environment, and supports 24-bit through a bit rate of up to 420kbps.
In addition, Qualcomm True Wireless Stereo Plus* mode minimizes transmission delay by transmitting independent signals to each earbud.
We hope you’ll enjoy the AK UW100’s benefits of premium Bluetooth technology combined with next-gen high-quality wireless codecs.
*Qualcomm True Wireless Stereo Plus: This feature requires a smartphone that supports Qualcomm True Wireless Stereo Plus.
Multi-Point and Multi-Pairing Support
AK UW100 supports Multi-Pairing and Multi-Point functions. Pair your earbuds on multiple mobile devices at the same time. Not only can you easily switch connections to another mobile device, but you can also listen to songs played on your tablet PC while actively allowing phone notifications and calls from your smartphone.
*The Multi-Point function supports a connection of up to two devices.
Battery Performance as Impressive as the Sound Quality
With AK UW100, there are no worries about continuous playback time, one of the key features of TWS systems. The earbuds alone stay running for a minimum of 6 hours and up to 24 hours, so you can enjoy music all day without worrying about power.
Alongside the convenience of wireless charging, AK UW100 also supports fast charging, so you can charge for 10 minutes to play for an hour.
Easy, Full-Touch Control
Precise full-touch control is enabled so you can simply tap to switch between functions: play music, answer calls, activate ambient mode, adjust the volume and more.
Voice Assistant Support
Tap the left earbud three times to activate your smartphone's Voice Assistant function. Control music playback, make phone calls and more powerful smartphone functions with your voice.
*The supported Voice Assistant function may vary depending on the specifications of each mobile device manufacturer.
Dual Mics for Clear Voice Calls
Integrating a Voice Communication Package (VCP) from voice application specialist Alango, the AK UW100 enables quality voice calls.
Based on special Acoustic Echo-Canceller and Noise-Suppressor technologies, the AK UW100 effectively reduces noise in a variety of settings and environments, ensuring call stability.
Easy Configuration with Our Proprietary App
Install the exclusive app to access various functions and configure the device with ease. With the app, you can customize the touch controls, ambient levels, various EQ settings, and more.
Internal Structure View
