Astell&Kern SP2000t Digital Audio Player (DAP)
Amplifier type
Solid-state, Vacuum tube
Wired, Wireless
Portability
365-day returns
Astell&Kern
Find Your Optimal Sound
- The Triple Amp System Takes Acoustics to a New Level.
- Vacuum Tube Amplifier Compatible with 2.5 mm, 3.5 mm and 4.4 mm Output Jacks.
- Equipped with ESS ES9068AS QUAD-DAC, for Balanced, Ultra Detailed Sound.
- TERATON ALPHA, Astell&Kern's Ultimate Sound Solution.
- ReplayGain Function to Maintain Consistent Playback Levels between Tracks.
- Dual-Band Wi-fi Support for Uninterrupted Wireless Connection and Improved Compatibility.
- Internal Mechanical Design to Minimize Noise
Introducing the A&ultima SP2000T. The Ingenious New Solution.
SP2000T
The "T" in SP2000T does not stand for a specific word, but rather encompasses design approaches and directions made during the product development process.
True
The SP2000T inherits the SP2000's true-sound philosophy
Triple
Triple AMP System
Timeless
Timeless Value
Tube
Vintage Vacuum Tube Amplifier
TRIPLE AMP SYSTEM is the Next Generation of AMP Technology
The SP2000T exceeds the standard approach to AMP Mode selection, based on the type of music you are listening to. Select between TUBE AMP mode, OP AMP mode, or the brand-new HYBRID AMP mode.
OP AMP mode puts Astell&Kern's AMP technology expertise to use, delivering extreme clarity and dynamic sound, while TUBE AMP mode provides a uniquely warm and musical sound.
HYBRID AMP mode - a first for digital audio players - enhances the resolution and clarity of the existing TUBE AMP mode to express more musical detail. HYBRID AMP mode, combines the advantages of retro analog performance and high-resolution output, giving you the pleasure of a brand new tonal characteristic.
Experience the unique sound enhancements that AMP technology has to offer.
OP AMP Mode : Extreme clarity and dynamic sound
TUBE AMP Mode : Uniquely warm and musical sound
HYBRID AMP Mode : A fresh combination of retro vibes and high-resolution output.
The SP2000T supports all output types, with no restriction on the type of receiver used, so you can enjoy the unique characteristics of the vacuum tube.
Real Vacuum Tube
Equipped with the portable-friendly dual-triode KORG Nutube, for a unique TUBE AMP sound.
Nutube offers a reliable continuous playback time of approximately 30,000 hours.It features an anode grid filament structure which operates the same as a triode vacuum tube.It's much smaller, consumes far less power and yet delivers the same audio with rich overtones.
The SP2000T supports all output types, with no restriction on the type of receiver used, so listeners can enjoy the unique characteristics of the vacuum tube.
HYBRID AMP MODE
HYBRID AMP mode supported for the first time by DAP is the essence of Astell&Kern's advanced AMP design technology.
New combinations of sounds can be enjoyed in HYBRID AMP mode,
which is based on the OP AMP sound and addition of tasteful warm tones unique to TUBE AMP technology.
Special Design to Minimize Microphonics Noise
SP200T features a special design tailored to minimize microphonics (the phenomenon wherein the vacuum tubes generate noise even from a small external impact). Multiple design iterations and verifications have been performed over a long period of time to fix the structural issues of vacuum tubes that generate microphonics noise even from a small impact or vibration.
For minimization of mechanical impact and vibration, both sides of the vacuum tube are fixed with flexible silicone covers, and the vacuum tube has been modularized so it is physically separate from the PCB. Astell&Kern goes to great lengths to innovate and design these small components that make a big difference in the quality and sound of our products that no other manufacturer can match.
Separation Using Magnetic Polarity
A structure that uses magnetic forces to float the amp in the air, thus minimizing noise from the vacuum tube itself, which is generated when it is exposed to mechanical impact or vibration
Flexible Silicone Covers
Silver Plating Shield Can
Astell&Kern products apply shield cans so that noise and elec-tromagnetic interference, which occur when the countless parts are in operation, do not affect the audio block.
The SP2000T has taken it a step further by applying highly con-ductive, hyper-pure silver plating on the existing shield cans for perfect shielding that provides excellent audio performance.
Astell&Kern Audio Technology Forms the TERATON ALPHA Sound Solution
AK ULTIMATE SOUND SOLUTION, TERATON ALPHA
TERATON ALPHA is AK's ultimate Sound Solution to produce audio playback that is close to the original sound through the audio output interface by use of effective power noise removal, efficient power management and amplification with minimal distortion.
TERATON ALPHA features Astell&Kern's patented technologies, which are the result of tens of thousands of hours of continuous research and development to produce sound close to the original sound the artist and producer intended.
Go to TERATON ALPHA >>Adoption of Full HD Display for Improved Image Quality
The SP2000T features a full HD screen to provide a higher quality display.
High pixel density
Large display
Large color gamut
High resolution
Quad-DAC for Perfection of Superior Sound
The SP2000T is equipped with four ES9068AS DACs, this allows two DACs per channel for dedicated decoding.
The SP2000T achieves a more detailed and balanced sound with great depth and spatial realism.
ReplayGain Automatically and Uniformly Adjusts Playback Volume
ReplayGain, which adjusts sound sources with different volumes to an identical level, has been applied. Now, enjoy your own playlists seamlessly through the ReplayGain feature on SP2000T.
- ReplayGain supports up to 24-bit/192 kHz sound sources.
Dual-Band Wi-Fi (2.4/5 GHz)
Dual-Band Wi-Fi is supported for users who enjoy streaming services, providing enhanced network performance.
With streaming music services becoming more popular, stronger and more reliable network reception becomes even more important for your audio experience.
The SP2000T supports Dual Band Wi-Fi (2.4/5GHz, a/b/g/n/ac).
AK File Drop to enjoy wireless transfers
The new AK File Drop function in the SP2000T makes files transfers easier and more convenient.
Using AK File Drop, you can freely transfer files wirelessly through a PC, smartphone, or FTP program located on the same network.
Music file management is now possible with a cableless, wireless solution.
Wireless Hi-Fi Sound Through BT Sink
The newly introduced BT Sink function connects the SP2000T to an external device via Bluetooth,
similar to connecting a smartphone with a BT speaker.
Music from an external device, such as a smartphone can now be played back in high-quality on the SP2000T using the BT Sink function.
Real-Time Playback and AMP Mode
Information Reflected by Light
Through the softly dispersing LED light,
Users are notified of the bit depth information of the song being played or the current AMP mode.
* LED light may be turned on or off in the user settings, and one can choose between
the sound source information or AMP mode information displays.
AMP Mode
Normal
Tube
Hybrid
Real-Time Information Confirmed by Light
16bit
24bit
32bit
DSD
