Astell&Kern A&ultima SP3000
Amplifier type
Wired, Wireless
Portability
365-day returns
Astell&Kern
Don't miss your chance to be one of the first to own Astell&Kern's newest flagship Digital Audio Player (DAP), the new A&ultima SP3000.
Sound Frontier, SP3000
Astell&Kern has set the standard for perfect sound using the latest innovative technology with the A&ultima series.
The A&ultima SP3000 is the newest flagship product that is the essence of everything learned and engineered over the last 10+ years of digital music processing.
- World's first DAP where digital and analog signal processing is completely separated by HEXA-structure DAC design
- First time Asahi Kasei's latest Flagship DAC AKM4499EX has been used in an audio product
- Stunning Audio Performance through Independent Dual Audio Circuits
- World’s first use of Stainless Steel 904L, typically found in luxury timepieces, for DAP body material
- Equipped with high-performance Qualcomm Snapdragon 6125 CPU
- Supports the latest aptX™ Adaptive Bluetooth codec
- New 4th Generation User Interface
Experience perfection firsthand with the true next-generation flagship, A&ultima SP3000, the pinnacle of audio players.
- World’s first use of Stainless Steel 904L for DAP body material
- World's first DAP with complete separation of digital and analog signal processing (Using latest Flagship DAC chip AKM4499EX from Asahi Kasei)
- Stunning Audio Performance with Independent Dual Audio Circuitry
- Equipped with High-Performance Qualcomm Snapdragon 6125 Octa-Core CPU
- New 4th generation Graphic User Interface
- Support for aptX Adaptive, the latest Bluetooth codec
Material Innovations - World’s First Use of Stainless Steel 904L for DAP Body Material
To achieve the goal of the A&ultima series, which is 'to provide the best value that no one can imitate while using the most innovative and uncompromising design and craftsmanship', the SP3000 uses 904L stainless steel material that has never been attempted before in a portable audio player. Using this material has expanded its value from just a digital device to the realm of a luxury good.
904L stainless steel is harder and more difficult to process than general stainless steel requiring significantly more time and effort. However, due to its excellent durability and corrosion resistance, it has a characteristic that does not lose its beauty and is why it is used in expensive luxury watches where perfection in all materials and parts must be pursued with an irreplaceable and wonderful luster.
Experience the uncompromising beauty and luxury of the SP3000 produced by Astell&Kern’s experienced craftsmanship.
In order to develop the ultimate audio player that has never been experienced before, not only do we use the latest DAC and technology available, but we use the innovative audio technology of TERATON ALPHA, AK's Ultimate Sound Solution, which has been refined for the SP3000.
TERATON ALPHA, engineered through endless research, is Astell&Kern's unique technology that has been designed to produce audio playback that is close to the original sound through effective power noise removal, efficient power management and unwavering amplification, and a fully converted audio output interface.
The HEXA DAC structure and independent dual audio circuit, implemented for the first time in the SP3000, are paired together with TERATON ALPHA's sound solution to create the purest original sound.
First Use of AKM’s Latest Flagship DAC –
Complete Separation of Digital and Analog Signals in a HEXA Structure
The SP3000 is a flagship product with the latest technology and uncompromising design. Astell&Kern worked with AKM from the initial development stage to develop the DAC and circuit structure.
As a result of the collaboration, the world's first four AK4499EX DACs, AKM's latest flagship, were applied to the SP3000, and the innovative HEXA structure design in which two AK4191EQs that process digital signals are applied separately, complete the amazing sound that can only be found from Astell&Kern.
Most digital players process digital and analog signals together inside the DAC. However, the SP3000’s advanced HEXA structure reduces the noise of the digital signal input through the AK4191EQ, a separate digital delta-sigma modulator, and the AK4499EX DAC is then designed to process the analog signals separately.
By applying this unique design, digital and analog signal processing that is physically separated has been achieved for the first time in a digital audio player, and the overwhelming SNR (Signal-to-Noise Ratio) is maximized, making it possible to experience an incredible level of sound that has never been experienced before.
Silver Plated Shield Can
A shield can is applied to prevent various noise and electromagnetic interference from affecting the audio block. The SP3000 takes it a step further to achieve excellent audio performance and perfect shielding by applying highly conductive, high-purity silver on the existing shield can, and physically separating digital and analog signals.
Stunning Audio Performance with Independent Dual Audio Circuits
In order to create a truly innovative DAP, not just a great DAP, we tried to overcome the limitations of sound by envisioning an independent dual audio circuit that has never been attempted by anyone with a HEXA structure with unbalanced and balanced outputs.
Almost all other DAPs, including Astell&Kern, use an internal DAC for both unbalanced and balanced outputs. Since the signal from the DAC is divided into unbalanced and balanced then delivered to the AMP, an Audio Switch is essential.
However, when using a switch, there is a limit to the range that can receive the signal sent by the DAC, so most DAPs reduce the signal size first and then when the signal is transmitted back to the amplifier, it is necessary to restore the original signal size. This causes a limitation in improving the audio performance.
To overcome the limitations, our engineers designed a HEXA structure using two AK4191EQs and four AK4499EXs, creating an innovative unbalanced and balanced independent dual audio circuit design. In result, the SP3000 achieves a SNR of 130dB, the best of any DAP available. You can feel the clean, pure delicacy of sound with the SP3000 that you cannot not experience in any other DAP.
Drive Your Music, Latest Snapdragon Octa-Core CPU for the Newest Flagship Device
A&ultima SP3000 is equipped with a Snapdragon 6125 Octa-core processor, so you can enjoy the overwhelming sound, faster system response and a redesigned 4th generation user interface that moves comfortably and smoothly.
Featuring a high-performance CPU and improved 8GB of DDR4 memory, which is twice the amount commonly used, the more powerful system is stable with fast and fluid movement.
The CPU, memory and wireless communication parts are configured as one module, with the digital circuit parts arranged in the same area creating a single system on a chip (SoC). This maximizes the efficiency of the overall circuit configuration by providing more audio-only circuit space as well as reducing heat and noise from digital circuits.
Heighten Your Music Experience – New 4th Generation Graphic User Interface
With the newly developed 4th generation UX/UI, the SP3000 is focused on the process and experience of listening to music, and we wanted to become a ‘player for music’ that one can feel this process.
The new theme is designed with a focus on the experience of rediscovering songs that you have forgotten; you can quickly browse through music categories with simple gestures. A convenient search feature along with album art has been added so that you can enjoy a digital display of CD album covers of your music collection. It is designed to give you not only the pleasure of listening to music, but also to create fun when operating the device.
In addition, the Crimson theme, one of the main features of the 4th generation UI, is designed so that you can feel the appearance of the SP3000 on the screen. The graphics are simple and unintrusive, focusing on usability and intuitiveness. Three key concepts, Edge, Simple, and Dark Mode, were used to improve usability and increase clarity with a style unique to AK. The black and red theme colors are chosen to reduce eye fatigue, maximize battery usage and reduce heat generation.
Sound Design With DAC Filters
With the SP3000, you can have fun creating your own sound style by selecting various DAC filters provided by the DAC manufacturer. Design your own sound with 6 different DAC filters.
Speaker Effect When Listening Through Headphones – Crossfeed
In a headphone environment in which the left and right channels are clearly separated, ear fatigue may increase during prolonged listening. The moment you turn on Crossfeed, the experience of crisp, but comfortable sound begins.
Crossfeed mixes parts of the original signal from one channel and sends that signal to the opposite channel with a time difference to center the sound image.
Through the use of detailed settings such as Shelf Cutoff, Shelf Gain, and Mixer Level, you can set the level of crossfeed according to your listening preferences.
QC 3.0 Fast Charging Supported
The SP3000 supports Qualcomm QC 3.0 fast charging, so you can charge your DAP faster and more efficiently than previous models, reaching a full charge in about 3.5 hours.
- QC 3.0 supports 12V/1.5A, 9V/1.67A, and/or 5V/2A adapters.
Premium French Goat Leather Case
The SP3000 comes with a French goatskin leather case to protect and highlight the beauty of the 904L stainless steel body.
The case is made by ALRAN, located in Tarn in southern France, a historical tannery that was established in 1903 and has been manufacturing leather for over 100 years. It is one of the world’s leading tanneries, well-known for their natural leather manufacturing technology since the 1980’s. ALRAN is recognized as the best goatskin manufacturer and supplies other leading luxury brands such as H and L.
The leather case included with the SP3000 is developed with ALRAN Tannery's unique Hand-Boarding technology. This is a technology that processes the leather by rubbing it in various directions using wooden planks, so you can feel the texture of the surface. This process is unique compared to how other goatskin cases are produced.
Design Concept – “Wrapped in Light”
The interpretation of light and shadow shown in the SP3000 is expressed as “wrapped in light” whereas the previous SP1000 and SP2000 expressed light as spreading and scattering. The concept of the SP3000 depicts how light gathers and wraps around the wheel.
This symbolizes that the SP3000 is the all-consuming culmination of all the technologies and capabilities that Astell&Kern has accumulated over the years. The polished stainless-steel body shines every moment, and the beautifully shimmering LED light and sharply machined ceramic panel further emphasize the luxury.
The SP3000, which was created through thoughtful design and processing, offers the ultimate in beauty that matches the ultimate sound.
